kmanstudios 1,120
20 minutes ago, GregValiant said:circles will always have facets
Flatland strikes!!😂
- 1
Flatland strikes!!😂
5 minutes ago, kmanstudios said:Flatland strikes!!😂
So I'm driving across Texas on a lovely day and I stop for gas. It happens to be a full service station and the fella comes out to pump the gas. I've been staring at the same scenery for 5 or 6 hours and I mentioned "Wow, is it ever flat here." to which he replied:
'Yep. If you stare in any direction long enough you'll see the back of your own head."
I like that one. Science in the middle of nowhere.
jirodriguez72 19
That's basically stair stepping due to layer lines. Easiest way to get rid of it is to change the orientation of the print, but that will probably lead to supports. Or there is a method out there called non-linear printing, but it involves digging into the g-code.
kmanstudios 1,120
In Cura there is a thing called "Use Adaptive Layers" in the experimental section. You can search for it in the search bar or go to preferences and check the box to make sure it is easily found. I have all my settings exposed to make finding things easier meself.
Hope this helps 🙂
GregValiant 1,351
PI has been taken to a 31.4 trillion decimal places with no end in sight. For us in 3D printing, that means there will always be steps and circles will always have facets.
