1 hour ago, GregValiant said:From HERE? It worked fine for me a minute ago.
Yep. I can click everything else but not the download button.
Browser issue?
I'm using Safari 10.1.2
Works for me. When you click the download link it does a popup where it asks you a few questions (which you can skip). You probably have popups disabled or maybe the popup is using some fancy javascript not supported in Safari.
Just to the right of where the URL is there are things one can click on - one of those in my browsers (firefox, chrome, ie, edge) lets you disable popups and it shows when it is blocking a popup as well. In safari maybe it's in the settings?
On 3/20/2021 at 7:35 PM, gr5 said:When you click the download link it does a popup where it asks you a few questions (which you can skip).
How long ago was it that you downloaded Cura for the last time? The survey has been removed around 2 years ago. Also the "popup" is not the type that popup blockers block, unless all javascript is blocked.
Edited by ahoebenSeconds before I posted the message above. But obviously I didn't read what popped up!
GregValiant 1,330
