kmanstudios 1,120
I took a look at the file. It is really messed up. 3DS MAX would not even import it:
I usually use MAX to check files as it is robust and has an STL checking system.
I did get it to load in 3DCoat. But it was still messed up.
Then I opened it into Cura 4.8 and it came in tiny (A). It also produced this error message about it not being manifold (B).
Scaling the model up in Cura I got this really weird shading. I have never seen this before.
I really do not think this car can be salvaged as it is.
Smithy 1,145
I haven't checked your file but in 99% of the cases the wall thickness is too thin. You can try to enable the Cura option "print thin walls".
