Yes its 2.85mm 'Standard White', and the same happened with the old print core using 2.85 orange
The printer is otherwise working normally and I can heat the print core, but it is not possible to pull the print core out with filament that has formed a flange like this as it cannot move up or down and the gap between the print core and head is too small to bend the filament to pull the print core out.
I'd also really like to work out how this is happening in the first place. Recently updated the printer to 6.3.0
Edited by sproutdesign
Carbon 28
Can you heat the print core? If you can this will help you remove the core.
Is the ColorFabb PLA you're using Ø 2.85mm?
