Well it can't write to that file. That file is the cura program itself. So here are some possibilities:
1) The most common - when I see that error - is that the program is running (cura is running). I'd launch task manager and make sure Cura isn't running.
Also go to that folder c:\Program Files\Ultimaker Cura 4.9.1\
see if the folder exists and see if Cura.exe is in it . If so then try to delete the file. If you can't delete it, particularly as administrator, then something has the program open. Worst case - reboot and try to delete it again.
The installer can't create Cura.exe (cura itself - the main program) if it's locked because it's currently running or open for some other reason.
2) Well maybe the file doesn't exist - maybe you don't have privilege to write to that folder. Maybe run the installer as administrator - right click the setup and choose "run as administrator"
1
ahoeben 1,886
Could you add a screenshot of the error? When the error is showing, just do Ctrl + PrintScreen, and then paste in a reply here. It will also help if you post a link to your Cura.log, which can be found in %APPDATA%\cura\4.9
Panther45 0
Ultimaker Cura 4.9.1 Setup
Error opening file for writing:
C:\Program Files\Ultimaker Cura 4.9.1\Cura.exe
Click Abort to stop the installation,
Retry to try again, or
Ignore to skip this file.
Abort Retry Ignore
I searched the drive for Cura.log and for %APPDATA%\cura\4.9 and for %APPDATA%\cura\4.9\Cura.log and found no results. Do you think the log is missing??
