Since the update I have restricted areas in cura. It did not matter until I wanted to print something big. I have a Anycubic Mega X and the print volume is big enough for the model, but it does not slice in cuase of the restricted areas, I will send you a screenshot. I sliced it a while ago (On cura 4.8 it worked perfectly) but I had not the fillament I wanted at the moment and I had the stl so I deleted the gcode and in general this wouldn't be a solution because I want to fix this, I searched for the problem but there was no solution (The solution for the ender 3 did not work).
Best regards,
Jonas
You have to reduce the "build plate adhesion", so you will reduce the restricted area.
erre-enne 0
Best regards
Luca
