GregValiant 792
PLA+ would be around 225. Regular PLA I would think to be 200-215.
For a non Ultimaker printer - you have calibrated your E-steps?
The filament diameter in Cura is correct? (1.72 is not the same as 1.75).
Typically when I use Spiralize I push my line width to 0.6 for a .4 nozzle.
I would want to fix the under-extrusion first. It may be easier to troubleshoot and the flowrate through the nozzle effects the temperature.
A line width of .35 is what Cura typically defaults to for an "engineering" profile.
Edited by GregValiantQuote
Speckles 1
and here I tried changing the line width to 0.4 and the initial layer height to 0.3 which made it worse on the first two layers badly unextruded. I did run this cylinder test (not 100% sure what it means but another user suggested I do this when I have underextrustion. This was at 220 temp
