give the precursor to the bowden tubes coming loose being no extrusion there are some more checks you can do.
can you check if your front fan still spins while printing? if this is barely spinning or not at all you'll need to clean out the tiny bits of filament that can get stuck in there.
https://support.ultimaker.com/hc/en-us/articles/360011635039-Check-for-debris-in-the-Ultimaker-S5-s-front-fan-of-the-print-head
Did you ever clean the printcore when this happened? There is a princore cleaning guide in the printer findable via: ⚙️-> maintenance -> print head -> print core cleaning
or alternatively have this useful guide wit visual examples of what the filament should look like though it was for the UM3
or this video for the S3 and S5 (note that you can also use PLA instead of "cleaning filament")
Travis7s 28
If you aren't using dual extrusion, then take the bowden clamp from the other feeder assembly and swap it in and see if that fixes it.
SandervG 1,522
That is also a good tip if you can't permit yourself any downtime, but I would recommend to get some new clamps from your reseller regardless! Good luck!
