Posted · Firmware 6.5.1 for S-line printers
Hi everyone, we released a performance and stability update for the Ultimaker S-line printers and products; firmware 6.5.1.
In this firmware update you will find a few things. Among others:
  • One at a time mode - We fixed the possibility of your print head colliding with a printed object when encountering an End of Filament while using one at a time mode.
  • Pause at height - When resuming a print that was paused automatically by the Pause at Height plugin, it was possible the extrusion was delayed. Resulting in a failed print. We fixed this.
  • Display print result after reboot - After rebooting your 3D printer after a failed print (usually prompted by an error message), it was possible the display did not display the correct status. We implemented several changed to ensure that after a reboot, the screen will display the correct status like 'Finished', 'Aborted', or 'Failed'.
  • ER65 false positives - ER65 is the flow sensor on the Ultimaker S5 Pro Bundle which sometimes gave a false positive due to a certain command in the code. We implemented a change to reduce the amount of false positives.
  • Stuck in preparing - For some users, their printer could get stuck in 'Preparing to print' state. This is now fixed.
  • Digital Factory connection - We made further improvements to make a more stable connection between your printer and the Digital Factory.
Official release notes can be found here
Download instructions can be found here by selecting your S-line printer
That was it, we hope you enjoy the new firmware!
  • Like 2
  • SandervG pinned this topic
  • 4 weeks later...
Posted (edited) · Firmware 6.5.1 for S-line printers
I updated, now have a failed print, saying excursion failed whilst in print! There should be an option to change spools manually if filamant is running low, the flow sensor did not detect filament was low and was forced to abort now i have height.sensor indifference error when trying 2nd print??
EDIT:-
I have tried the 2nd print and at the same time, to finished roughly I got same error..I am pretty sure this is an update firmware issue causing this, as the machine never did this b4..?
I am now scared to use the printer because 8 hrs into a print job i get these errors..
Edited by Navin2020
    You always been able to change filament mid print if the spool is getting low.
    To do this:
    1. Press the printer icon on the touch screen.
    2. Press the button the filament you want to change.
    3. Press the "Change" button.
    4. The printer will than Pause the print for you and you can then change the spool as normal, when done the printer will then start to carry on printing.
    Also you can tune the print settings mid print also via the 3 dots button, where you can also pause the print if needed also.
    Edited by Carla_Birch
    @SandervG
    I keep getting an error with my printer: print head offset.
    Previously when I got this issue, it just asked if I wanted to re-try.
    After the firmware update:
    1. I get a failed message.
    2. The printer locks out while it cools down.
    3. It asks if part was removed (even through it did not extrude anything).
    Now it takes 20-30 minutes to clear this error.
    Can you change it back to the way it was previously implemented?
    Thanks,
    Tim
    Hi @Tim_Cochrane thank you for your message. Which printer do you run? Is the message referring to X/Y being offset or while probing during the active levelling? Did you perform a new calibration after getting the error message, and does it keep coming back?
    Do you mean change this firmware? If there is a crucial bug that needs to be fixed we will look into it. Or do you mean that you want to revert back to the previous firmware version? Thanks,
    Hi Tim, thank you for your response. Before we would be able to make such a call we would need to review your log files and collect more data from other users. So at this point, that would be too soon to tell. I am also still not sure what exactly your issue was, some questions in my previous post are still unanswered that would help me understand. If you still need any help, it would be helpful if you could describe your issue more specifically and if it has happened once or every time you try to start a print. Thank you for your time,
    To do this:
    I have a material station and the option to change filament is greyed out..not selectable
    Edited by Navin2020
    spelling
    My S5 pro keeps hanging at random points in the print process, sometimes it starts heating up and hangs there, sometimes it prints and hangs after removal, sometimes if I abort a job it hangs, sometimes it works flawlessly. It hangs more often than it works however. I have attached the logs.
    ultimakersystem-0030d623dde0.6.5.1.boot-1.log.zip
    I stopped using the printer because i scared of getting failed prints, it is costing me a fortune
    On 9/30/2021 at 6:47 PM, dboito said:
    I've had a look at your logs, and the material profile you use is not made for the "Material Station"
    You can see that the printer is missing several bit of information:
    Sep 30 16:08:14 ultimakersystem-0030d623dde0 PrinterService[1261]: 2021-09-30 16:08:14,642 ERROR    deprimeManager  Not all parameters present in material profile (3D4Makers Facilan C8 Generic).
    Sep 30 16:08:14 ultimakersystem-0030d623dde0 PrinterService[1261]: |{
    Sep 30 16:08:14 ultimakersystem-0030d623dde0 PrinterService[1261]: |    "break preparation temperature": "value to be replaced",
    Sep 30 16:08:14 ultimakersystem-0030d623dde0 PrinterService[1261]: |    "break preparation position": "value to be replaced",
    Sep 30 16:08:14 ultimakersystem-0030d623dde0 PrinterService[1261]: |    "break preparation speed": "value to be replaced",
    Sep 30 16:08:14 ultimakersystem-0030d623dde0 PrinterService[1261]: |    "break temperature": "value to be replaced",
    Sep 30 16:08:14 ultimakersystem-0030d623dde0 PrinterService[1261]: |    "break position": "value to be replaced",
    Sep 30 16:08:14 ultimakersystem-0030d623dde0 PrinterService[1261]: |    "break speed": "value to be replaced",
    Sep 30 16:08:14 ultimakersystem-0030d623dde0 PrinterService[1261]: |    "park_temperature": 125,
    Sep 30 16:08:14 ultimakersystem-0030d623dde0 PrinterService[1261]: |    "park_position": -120.0,
    Sep 30 16:08:14 ultimakersystem-0030d623dde0 PrinterService[1261]: |    "park_speed": 10.0,
    Sep 30 16:08:14 ultimakersystem-0030d623dde0 PrinterService[1261]: |    "maximum park duration": "value to be replaced"
    Sep 30 16:08:14 ultimakersystem-0030d623dde0 PrinterService[1261]: |}
    Unfortunately we initially only tested on the presence of a few values making the behavior rather random since the behavior depends on when it needs a missing value.
    While we have added a pop up error for this in 7.0.0, that release is taking a bit longer to finish then we'd like.
    I'm fairly confident that if you print with a more complete material profile, so try and replace your "3D4Makers Facilan C8 Generic" profile with a comparable Ultimaker or generic one or update that profile.
