GregValiant 1,330
A couple of things here. The print speed is governed in part by the minimum layer time. Cura will make adjustments to try and hit the minimum time if your print speed causes a layer to finish too quickly. It's a cooling thing. You will run into that a lot when you use Spiralize (vase mode).
Consider: Your print speed is 60mm/sec and your minimum layer time is 10 seconds. You have a layer that indeed takes 10 seconds at 60mm/sec. If you raise your print speed to 2000mm/sec but leave the minimum layer time at 10 seconds, that layer will still print at 60mm/sec.
As Obewan says, the "Z-Hop Speed" (found in the Cura Speed settings) pretty much governs the Z speed BUT the maximum that Cura will allow you to enter in Z-Hop Speed is "machine_max_feedrate_z" which may be set in your printer definition file. You can change machine_max_feedrate_z in the "Printer Settings" (which needs to be loaded from the MarketPlace) which has a box for "Maximum Speed Z". You can set Maximum Speed Z to whatever you want.
The real limit to Z speed is in your firmware in M203. No matter what you enter in Cura, when it gets to the printer the numbers in M203 will be the upper limit for each axis. You should enter the M203 numbers into Cura. There is no way that Cura can query the printer to pull those values.
obewan 37
This is set by the Z hop speed
