GregValiant 950
You're too quick @Torgeir. I was busy trying to repair the model but didn't have any luck. It isn't watertight and there are some other errors. The model really needs to be fixed in the CAD software.
BTW, what software did you use for the design?
Edited by GregValiant
Torgeir 211
Hi @Liampeffers
Welcome in here.
There is nothing wrong here, -except that the wall thickness at this point is "super tiny", so there is no printer like we're using that can handle such a sharp edge. You'll need to redesign your model so the wall thickness have width the printer can handle.
Cura slicer in preview mode will show how your model will look like as it "know" the limitation..
Just select a wall size at "around" 0.3 mm and see how this goes.
Good luck.
Thanks
Torgeir
