Setting the 'support Z distance' too 0 will start the support on layer 2 instead of layer 3.
1
16 hours ago, Torgeir said:
Thanks for looking, Torgeir.
Your image is on layer 16 or 18. Can you look at layer 2 and layer 3 (or 3 and 4, depending on the layer thickness you use) instead?
Edited by FrankSchwab
15 hours ago, obewan said:Setting the 'support Z distance' too 0 will start the support on layer 2 instead of layer 3.
Ding, Ding, Ding, I think we have a winner! This isn't a "bug", it's a "feature". After finding the setting and reviewing the docs, I understand now, and this is intentional behavior to allow supports to be easily removed on the bottom side as well as the top side of the support.
Sigh. 10 million options. Some day I'll learn half of them.
Thanks, obewan.
Ok., thanks for the feedback.
Torgeir
Torgeir 248
Hi @FrankSchwab
Welcome in here.
I downloaded your file and looked at it using Cura 4.10.0.
It came up just fine for me, -cannot see any problem - here's a picture in preview mode.
Here you see the support for the top of the closed cylinder (yellow climbing "zig-zag" pattern), the blue infill in between the wall -and there is also a tiny support in between the top layers.
I'm using only skirt found under "Build Plate Adhesion".
Maybe I'm missing something here?
Thanks
Torgeir
Text error.
