10 hours ago, ahoeben said:It looks like they may be part of the model. Can you save a project (File -> Save project...) so we can check out both the model and your settings?
Project attached. It's a Thingiverse STL so I don't have the original model. I found a few other anomalies, extra interior walls that aren't attached to each other. I've tried running it through MeshLab following a tutorial and while it found and fixed several problems it still shows up the same in Cura. Strange thing is I tried slicing it with PursaSlicer and none of those show up and there's no message of it not being watertight.
ahoeben 1,766
