I'm new to cura slicer & installed 4.11
Things ive noticed
Materials to not actually install. Nothing on the local drive pertaining to any of the materials i imported (Mainly ProtoPasta)
- This is an issue ive seen in multiple 3rd party forums - no solutions found
I also cannot find mesh modifiers or any way to add shapes to increase structure strength.
- I've seen these in older versions on youtube, but cannot locate them in 4.11, so ill be installing 4.10
Has anyone else had these issues? Found any solutions?
    Posted (edited) · 4.11 Bugs
    The materials in the Marketplace currently only work for Ultimaker printers.
    Cura 4.11 comes with a set of all new icons, so the tool you are looking for to access "mesh modifiers" may look different now, but it is still there. The support blocker tool (that lets you add the cubes) is the 6th one from the top, the per model settings tool (that lets you change what the cubes do) is the 5th.
    Edited by ahoeben
