UlrichC-DE 108
Hello
If the feeder is set too strong, this can happen. A cork then forms in the feed. The print head can then be easily cleaned with cold-pull. Most of the time, it is not even really clogged. After the failed print attempt, you can print again from scratch without cleaning.
The feeder then mechanically makes a too wide retract.
If necessary, I would turn the feeder (tension) to the middle position.
jeroensmith 1
wellicht helpt de bijgevoegde foto. Dit is hoe het filament steeds uit de printcore komt.
