12 hours ago, tinkergnome said:What happens, if you choose a more reasonable feedrate (e.g. F40 instead of F300)
Right! There is a flow rate field just below the extrude control in the octoprint dialog. I tried to set it to 20 %, but it somehow wouldn't bite.
On the other hand I didn't want to believe in that, because I would expect the extruder to skip if that was the case. It felt smooth and silent. Was that a wrong assumption?
Edited by gauthier
tinkergnome 927
If my calculator is right, you try to extrude more than 30mm³ per second. Are you sure that your printer can handle this?
That's nearly 8 times more - compared to the feedrate in the linked article.
Don't forget that these instructions are made for a much smaller filament diameter (1.75mm).
What happens, if you choose a more reasonable feedrate (e.g. F40 instead of F300)?
ahoeben 1,955
Good thinking @tinkergnome! And here I was caught up in the fact that 100 / 35 is about equal to the filament diameter, and I could not figure out why/how that mattered 😉
