It looks like the model does not have a flat bottom, and/or it is not 100% flush to the bed. You can get a better skirt by pushing the model into the bed by a tiny amount (ie: setting the z to -0.1 or so).
Oh. I'm embarrassed. This is not a bug. I should have had @KingOli post the project file here for me to look at before suggesting cura issues.
The part that the skirt goes "under" is not touching the build plate. If you want the part to touch the build plate then the 4 portions that are over the skirt need to start at the same height as the rectangular portion that they are attached to.
Or as @ahoeben says, you can set Z to a slightly negative value but to do that you have to first go into the cura preferences menu "preferences" "configure cura" select "general" and uncheck "automatically drop models to the build plate".
gr5 1,971
Sounds like a bug. It would be good if you guys could post this as an "issue" on github. Unfortunately you need a github account but it's easy and free. Then post the issue here:
https://github.com/Ultimaker/Cura/issues
Also include the project file (which contains the STL, and all your settings) that reproduces the issue. The developers are very busy and if they can't reproduce your issue the first time they are likely to move onto another issue. To get the project file do "file" "save project file". Also it's best if you verify that the problem is in the latest copy as they might not know if it is something that was fixed in the latest cura.
KingOli 0
Thanks gr5, I have opened issue #11174.
