Dim3nsioneer 557
two more things to check:
- are the belts tightened?
- are the belts too tight? You would hear a quite loud noise from the stepper motors when they skip steps.
What size are the shifts? cm? mm? tenths? A picture of the shifted print might help to find the source...
burki 1
Is that a repeatable problem? Have you checked the layer view in Cura, to see if it's a problem in the gcode?
Plus, you may want to tighten the grub screws in your pulleys.
