Outer wall defects, might be a slicer setting issue
Hibino
Posted (edited) · Outer wall defects, might be a slicer setting issue
Hello everyone, I am using Cura 4.12.1 and having some trouble with one of my prints and I've spend almost 2 weeks on it but just can't figure out what went wrong.
All the prints are done with 60mm/s, Inner/Outer wall at 30mm/s, same temperature(200 nozzle, 60 bed)
The defects always happen on the same spot even with different printer(Anycubic Vyper and Creality Ender3 Pro)
vyper.thumb.jpg.26109cb63f7aa76e24063d6a25cc80ff.jpgender3.thumb.jpg.c602f624c85f292db2ecfc6a0dd74f37.jpg
After tried lots of calibration/firmware/turning the defects just won't go away. So I tried a different slicer with their default settings, it seems the defects does not show up in PrusaSlicer or IdeaMaker(Although they have other problems since I haven't got much time to change their settings yet)
I looked into the GCode preview where the defects happens, but can't find any problem with it, they looked like straight line in the preview.
cura.thumb.png.69b84acbe5abbf9eb36873c117f8700a.pngidea.thumb.png.a64ecd40366686199cbf1414b7fcabae.png
Since PrusaSlicer and IdeaMaker does not having this issue, I guess this might be some setting I used in Cura causing this, it will be greatful if anyone can help me find the right setting. Thank you.
I've attached the STL model "hueca cisne.zip" if it helps the diagnosis, I enlarged the model by increased the model Z axis to 70mm when slicing
hueca cisne.zip
Edited by Hibino
Remove duplicate image
    Posted · Outer wall defects, might be a slicer setting issue
    Look through the different gcode files and see if you can determine the Acceleration and Jerk settings (M201, M204, and M205) as well as the speed settings (the "F" numbers).  The problem looks to be ringing (but might be an extruder issue).
    If you do not enable Accel and Jerk control in Cura then I believe that the printer will fall back on it's defaults which might be too high for that particular model.  For some reason (probably mechanical) you are getting a bounce in that axis.  It might be caused by different Accel and Jerk settings in the Cura file and a harmonic vibration is showing up in the print.
    In the Prusaslicer photo you can see an issue on the left that might be the same sort of thing, just in a slightly different location.
    Thanks GregValiant.
    I checked all 3 GCode files they do have M204 S1200 at begining of file(except IdeaMaker which have M204 S2500 after every layer finish moves to layer start point and M204 S1200 again, guess the setting in IdeaMaker have travel acceleration set to 2500).
    There is no M205 since Jerk control is not ticked in slicer settings and the firmware I have is using junction deviation(set to 0.07).
    Only PrusaSlicer's GCode has M201 X3000 Y2000 Z60 E10000 at begining of the file, there is no M201 in other two slicer's Gcode file.
    1200 is the default acceleration of Vyper and 500 is the default acceleration of Ender 3(acceleration control is disabled on Ender 3 profile)
    I thought it was extruder issue(uneven extrution) so I replaced the extruder on Vyper with the BMG extruter and a new nozzle but same defects happens at the same location, until I tried on Ender 3 having the same issue I starting believe it might not be hardware related.
    The print from PrusaSlicer does have some defects on the left where there is a L sharped corner, maybe it is running too fast around that corner.
    I am resizing the model to difference sizes and slicing with Cura see if it happens on a certain height at the moment, will take few days to test out again...
    Edited by Hibino
    After few prints I got a very interesting result.
    The defects is not height related and always will be on the same spot so I can move the model down below the bed in Cura to only print where it happens.
    The top 4 is still sliced with Cura 4.12.1 with different model size/print speed/acceleration, even at 20mm/s speed the defects always be there.
    The last one is sliced with the Beta Cura Arachne which I saw on this forum. I installed it and it loads up all my current Cura 4.12.1 profile and settings, I didn't change any setting just used it to slice the model(resized model height to 70mm), and printed the section where defects happens, it came out like PrusaSlicer and Ideamaker with no defects on the outer wall. I feel there must be something weird with my Cura 4.12.1
    Edited by Hibino
    Correct version number
    • Confused 1
    • 1 year later...
    Hey !
    Bad & good news - you are not alone.
    We have the exact same problems and we were also on v4.12.1.
    First I thought it's the Z-axis, but as you can see, the back of the model was printed really good
    without any issues @0.16mm LH. The model also does not have any anomalies. Problematic is the
    printed front (most cooling) and it begins after 8-10mm of model hight. These problems are definitive slicer
    dependant, as "SuperSlicer" does not show these issues at all.
    It's a shame that Ultimaker dropped CURA support for older Windows versions and stopped the official v4 branch. Many schools here with ~20 printers and older Win7/8 offline machines were all forced to move to another software or upgrade to win10 for big $$$$. Think of it (@Ultimaker) EVERY other slicer on the market runs from WindowsXP upwards without problems !! Forcing useres to use Windows 10/11 is a really bad thing and I can't stand these bad decisions like "but the new framework requieres win10" anymore. So, don't think you get support for CURA v4 here, they made'em easy.
    Back to our problems: there are many other, more caring users, integrating new features, fixing problems and other stuff to the older v4 branch of CURA. We haven't tested this version, as we moved to another slicer, but it's really worth a try to see if these issues were fixed if you are using an older operating system.
    You could download the latest v4.20.10 of CURA here:
    https://github.com/smartavionics/Cura/releases/tag/4.20.10
    Or take the other road and get rid of these "outer wall bulbings" with another slicer:
    https://github.com/supermerill/SuperSlicer/releases/
    (SuperSlicer is a fork of PrusaSlicer receiving very frequently updates & fixes)
    Hope that helped.
    Godi
    Edited by Stratasys
