2 minutes ago, gr5 said:Does it slice if you don't pass it any configuration file?
Do you mean not using the "-j "cobod_bod_2.def.json" parameter? If you do, then my answer is no, it doesn't:
d:\Program Files\CuraEngine\Install\bin>CuraEngine.exe slice -v -p -o "CuraDebug.gcode" -l "MyFriends Basement.stl" Cura_SteamEngine version master Copyright (C) 2021 Ultimaker ... *license stuff* ... along with this program. If not, see <http://www.gnu.org/licenses/>. [ERROR] Trying to retrieve setting with no value given: 'mesh_rotation_matrix'
gr5 2,334
@ahoeben might be able to spot an obvious issue.
