Thanks. I did some more test print with different settings on "Initial Layer Flow" in Cura. Pictures appended are taken upside down with 100% and 125%. What bothers me is that it really only is the first layer that are underextruded. The rest of the print is of very good quality.
I found the TFM coupler as spare part (e.g. here: https://www.igo3d.com/Ultimaker-TFM-Isolator-Coupler-UM2-), but I did not find the spacer you mentioned. Where do I get it? If I disassemble the print head, I want to do both at the same time.
IRobertI 496
Looks like underextrusion to me. I'd start by checking that the nozzle is clean and also, probably more likely, check the status of the PTFE coupler. On the old UM2s that part was quite often the problem:
https://support.3dverkstan.se/article/56-replacing-the-ptfe-coupler
If it's worn out, replace it with the newer TFM (PTFE vs TFM is simply the type of material used for the coupler) for the UM2+. Also replace the spring with the spacer used on the 2+ and you'll have much much longer life on that part.
edit: As for the PLA being old. Yeah, it does age, but personally I've used 10 year old PLA and it works just fine.
