3 hours ago, ahoeben said:You can have them both side by side. If the 4.13.0 AppImage still launches without a problem, then something went wrong when building the 4.13.1 AppImage.
Thanks @ahoeben, I'm keeping the old AppImages around, just in case. The previous ones are all working fine. Only the new 4.13.1 seems to be affected.
ahoeben 1,586
No, they should not have.
The 4.13.0 AppImage is still available here:
https://github.com/Ultimaker/Cura/releases/tag/4.13.0
Just to be sure, @nallath, was the Linux build-system changed/updated between 4.13.0 and 4.13.1?
Edited by ahoebenLink to post
