Posted
· TPU support structure issues - Support Z Distance
TPU sticks to itself really well. Your "Support Interface Density" of 100% is effectively just another layer. You can try using something like 40% but the first layer above support doesn't get any "squish" and never looks as good as layers that go down on the bed or on top of other layers.
A hobby knife is your friend.
The "Support Z Distance" can only be exact multiples of your layer height. If the Layer Height is 0.3 then your Z distance could be 0.0, 0.3, 0.6, 0.9, etc. Cura cannot vary layer height during a print.
I usually use "Grid" linetype for the Support Interface and at densities ranging from 25% to 60% and .6 to 1mm thick (depending on the model).
I limit my TPU printing to flat gaskets and some seals because it is so hard to clean up after printing.
I did some experimenting using a Pause at Height when the first layer above support was supposed to go down. I had pieces of blue painters tape prepared and sprayed with hairspray. At the pause I would put them over the support and the first layer above the support went down better. It was more trouble than it was worth.
GregValiant 988
