Some of the commands are not useful for the UM3, like cooldown phase which doesn't exist on the UM3.
But you can use the tool on the UM3 to remotely confirm that you have removed the object. (cleanbed command)
When I wrote the tool, I did some tests with my UM3 and it worked, but I was not able to test several firmware version.
You can try it on your UM3, the command cleanbed is safe, it doesn't modify anything in the firmware, it just sends a trigger to the message bus internally.
2
gr5 2,005
I think maybe now there is a way. You need ssh access to the printer so that means it has to be in developer mode and it has to be visible network-wise from where you are. But if you have a vpn to the workshop then I think the answer is yes?
Okay reading the link below the UM3 is not supported but I think you could be a beta tester. @Smithy can this guy try your tool with a UM3 - please read above.
