You are "leveling it wrong". Which is very common and very understandable and I don't know what you are doing wrong just that you need more squish. So don't level any more - just turn the 3 screws counter clockwise as seen from below to move the bed closer to the nozzle.
Turn all 3 the same amount so you don't have to do the leveling procedure again.
It's 0.5mm per full turn so try turning half way, start the print and be ready to turn them some more when it prints the skirt or brim. Remember - CCW as seen from below squishes more. CW squishes less. If you practice this at the start of every print eventually you will be able to do it without thinking. Anyway that's not ciritical as once you get the leveling perfect it should stay great for many months (or until you change the nozzle or other hardware that changes the nozzle position).
Smithy 1,088
There are only two possibilities, level a bit closer to the bed to increase the adhesion or try another adhesion agent. For PETG hairspray, Dimafix, 3DLac or Magigoo is working.
Strange is that it was working before with the same glue stick as far as I understood. So I would try to level a bit closer and try it again.
