Probably a loose/bad wire. Check the wires going into the green connectors on the print head board, and also the connectors where the wires leave the board to go back to the electronics. Also remove the cover over the electronics under the printer, and check the temp sensor connector there.
If that doesn't fix the problem, then there's a spare pair of wires from electronics to print head - use that one instead of the pair currently running between little green board and the electronics. Swap it at both ends - it may be the wires are damaged in the existing wore pair.
IRobertI 513
Since it's only acting up while the head is moving I'd suspect a glitchy connection. I'd start by checking that the wires on top of the print head are firmly in place. It's two thin wires that go into a screw terminal on top of the print head. Also trace the other wires going from the print head along the bowden tube and make sure they're connected together solidly.
