I am having the same problem with Cura 5.2.1, an Ultimaker 2+, and the Ultimaker-supplied 0.6mm nozzle.
Layer adhesion seems fine, but the line width is clearly too narrow – I get the same kind of waffle effect described above.
I do seem to be able to mitigate it by cranking up the flow rate in Cura (> 150%), but I feel like that's going to cause other problems (?), and without knowing what's going on, I don't know exactly what the nominal value should be.
Looking at the G code, lines are correctly spaced (0.55mm apart) in both the top and bottom skins.
GregValiant 980
Use the File/Save Project command and post the 3mf file here.
When I slice with a .6 everything looks good. I was using .3 layer height, .6 line width, 100% Initial Layer Line Width, and all flows at 100%. There are a couple of other settings that affect the E numbers (amount of overlap, wipe distance, etc.) but the ones I adjusted are the main ones.
