Maybe I don't understand it yet but if you forget to save the changes to the current profile and switch to another you have lost the changes for the current profile, you then only have the option to save the changes to the profile you want to enter.
I expect to get the option to save the changes to the profile the changes were made in, the option to save it to the profile to be opened for me is of no use. I want to do that manually, if needed, as that gives more control over the changes.
I have not discovered the logic in this and thus I still mess up more than once switching profiles which is a real pain.
I have for example printed a couple of plastic bearings to tune the horizontal expansion on the in and outside. Now I have lost the values for that and can start over again.
Edited by Mechatron127
nallath 1,123
You have "unsaved" changes and "saved" changes. By default, if you have unsaved changes and switch a profile, Cura asks you what you want to do; Either keep the unsaved changes or discard them.
There is also a preference that you can set where it won't ask you every time you do this, but pick either of these two options. I assume that that is what you set. If you want to change that behavior, you can find it in preferences (general page)
