8 hours ago, GregValiant said:Zooming into your images I believe that Extruder 1 is really under-extruding the black.
I think the same, it should be a flat surface, but you have a "structure" in it.
Do you use a default profile or have you changed a lot of settings?
Are the print cores clean and have you also checked the feeder and feeder tension? The marker should be in middle position.
Which filament do you use?
Can you also take a picture from the bottom of your model?
GregValiant 1,491
Zooming into your images I believe that Extruder 1 is really under-extruding the black. Your Top/Bottom flow is at 97%. I believe the under-extrusion is much higher than 3%. You might not be getting enough squish.
It's an S5 so @gr5 or @Smithy may have ideas?
