22 hours ago, gr5 said:It could just as easily be the glass versus the plate under the glass. Remove the glass from the heater plate and test them separately to see where the issue is. I have personally unbent a heater plate using my fingers alone (took most of my strength) only to later realize I could have cracked a trace on the heater under there. Fortunately no harm done in my case.
I was able to test the flatness of the glass and it is definitely the plate under that glass that is warped. I take it that you would not recommend that I try to unbend it with my hands even though it worked for you.
22 hours ago, gr5 said:What country are you in?
The US
Is it less than a year old? If you don't know you can find out using only the serial number but first: what country are you in?
It was purchased in 2019
gr5 1,837
