fieldOfView plugins for Cura 5.0
ahoeben
Posted (edited) · fieldOfView plugins for Cura 5.0
With the release of the Cura 5.0 beta, a lot has changed in the core of Cura. So much so, that in order to be compatible with Cura 5.0, all plugin need to be updated and resubmitted to the Marketplace. I maintain a number of plugins, and you can imagine that it takes a while for me to update the plugins but also for the Ultimaker dev team to review them. I will use this post to share with you a growing set of pre-release versions of my plugins so you can test them with Cura 5.0 beta.
Edit:
All plugins are now in the Marketplace, and the prereleases for these plugins below should no longer be used (but will remain available on github)
OctoPrint Connection: https://github.com/fieldOfView/Cura-OctoPrintPlugin/releases/tag/v3.7.0-DEV
Mesh Tools: https://github.com/fieldOfView/Cura-MeshTools/releases/tag/v3.7.0-DEV
Sidebar GUI: https://github.com/fieldOfView/Cura-SidebarGUIPlugin/releases/tag/v4.3.0-DEV
Measure Tool: https://github.com/fieldOfView/Cura-MeasureTool/releases/tag/v1.1.0-DEV
Z Offset: https://github.com/fieldOfView/Cura-ZOffsetPlugin/releases/tag/v3.7.0-DEV
Linear Advance: https://github.com/fieldOfView/Cura-LinearAdvanceSettingPlugin/releases/tag/v3.6.0-DEV
Edit 4/23:
OctoPrint Connection: https://github.com/fieldOfView/Cura-OctoPrintPlugin/releases/tag/v3.7.0-DEV (updated)
Arc Welder: https://github.com/fieldOfView/Cura-ArcWelderPlugin/releases/tag/v3.6.0-DEV
Start Optimiser: https://github.com/fieldOfView/Cura-StartOptimiser/releases/tag/v3.6.0-DEV
Titlebar Info: https://github.com/fieldOfView/Cura-VersionInTitlebarPlugin/releases/tag/v3.6.0-DEV
Automatic Slicing Toggle: https://github.com/fieldOfView/Cura-PauseBackendPlugin/releases/tag/v3.6.0-DEV
Edit 4/25:
Printjob Naming: https://github.com/fieldOfView/Cura-CustomJobPrefix/releases/tag/v3.7.0-DEV
Material Cost Tools: https://github.com/fieldOfView/Cura-MaterialCostTools/releases/tag/v3.6.0-DEV
Setting Visibility Set Creator: https://github.com/fieldOfView/Cura-SettingVisibilityProfileCreator/releases/tag/v3.6.0-DEV
Printer Settings: https://github.com/fieldOfView/Cura-PrinterSettingsPlugin/releases/tag/v3.6.0-DEV
Edit 5/6:
Material Settings: https://github.com/fieldOfView/Cura-MaterialSettingsPlugin/releases/tag/v3.6.0-DEV
I will update this list with prereleases of other plugins, or when a new prerelease is necessary to fix a bug.
To download these prerelease versions, go to the linked page and scroll down to the 'Assets' section. There you will see curapackages compatible with different versions of Cura. For Cura 5.0 you will need to download the file ending with `Cura5.0.curapackage`. After downloading that file, drop it onto the 3d viewport in Cura 5.0 as if you were opening a 3d model. You will then be prompted to restart Cura. You can drop multiple curapackages one after the other without restarting each time if you want to install multiple plugins. If you want to test these updated release in an older version of Cura, please download the curapackage labeled for that version.
It is quite early days, and some of the plugins required extensive work to make them compatible with Cura 5.0. Feedback is welcome, either here or in the issue queue for the respective plugins.
Edited by ahoeben
  • Thanks 10
Posted · fieldOfView plugins for Cura 5.0
At this point the sidebar GUI should be somehow in cura by default.
This GUI of yours is so much better than the default one that ultimaker should make you a deal of some sort.
Everytime a new cura version comes out I get reminded that this is a plugin from a user and not the cura default because it is one of the first things I check for new versions.
Easily the best plugin. Once used you don't want to miss it!
  • Like 4
Cura 5.0.0-beta1 on Linux (AppImage) crashes with the following traceback when installing the Octoprint Connection plugin:
Traceback (most recent call last):
File "cura/CuraApplication.py", line 1109, in event
return super().event(event)
File "UM/Qt/QtApplication.py", line 489, in event
event._function_event.call()
File "UM/Event.py", line 218, in call
self._function(*self._args, **self._kwargs)
File "UM/Signal.py", line 328, in __performEmitIndirect
self.__performEmit(*args, **kwargs)
File "UM/Signal.py", line 357, in __performEmit
func(dest, *args, **kwargs)
File "/home/hwa/.local/share/cura/5.0/plugins/OctoPrintPlugin/OctoPrintPlugin/OctoPrintOutputDevicePlugin.py", line 300, in addInstance
self._configureAndConnectInstance(instance, global_container_stack)
File "/home/hwa/.local/share/cura/5.0/plugins/OctoPrintPlugin/OctoPrintPlugin/OctoPrintOutputDevicePlugin.py", line 321, in _configureAndConnectInstance
instance.connect()
File "/home/hwa/.local/share/cura/5.0/plugins/OctoPrintPlugin/OctoPrintPlugin/OctoPrintOutputDevice.py", line 459, in connect
self._update() # Manually trigger the first update, as we don't want to wait a few secs before it starts.
File "/home/hwa/.local/share/cura/5.0/plugins/OctoPrintPlugin/OctoPrintPlugin/OctoPrintOutputDevice.py", line 427, in _update
self.get(end_point, self._onRequestFinished)
File "/home/hwa/.local/share/cura/5.0/plugins/OctoPrintPlugin/OctoPrintPlugin/OctoPrintOutputDevice.py", line 1823, in get
request = self._createEmptyRequest(url)
File "/home/hwa/.local/share/cura/5.0/plugins/OctoPrintPlugin/OctoPrintPlugin/OctoPrintOutputDevice.py", line 1783, in _createEmptyRequest
request.setAttribute(QNetworkRequest.FollowRedirectsAttribute, True)
AttributeError: type object 'QNetworkRequest' has no attribute 'FollowRedirectsAttribute'
Thanks, I am on it.
The OctoPrint Connection plugin linked above has some issues to work out still.
I am happy to confirm that I can install this plugin without crashing. Sending files works but the job does not start automatically yet. I assume that's tied into the currently-not-working Monitoring tab or my settings ...
    Did this work in Cura 4.13 with the version of the plugin that is currently in the Marketplace?
    Can you test this prerelease of the plugin with Cura 4.13? Be sure to download the appropriate .curapackage for Cura 4.13 (from the same page).
    The monitor page just shows the state of OctoPrint and has little to no effect on the print starting after uploading.
    The last released-to-Marketplace version worked for 4.13, and the prerelease version works as well, including the monitoring tab. I have not tried running a print yet as another is currently active.
    • Thanks 1
    ArcWelder works.
    Start Optimiser does not work, after installing it reset the settings. It is installed in the Roaming\cura\5.0\plugins folder and not in Roaming\cura\5.0\plugins\StartOptimiser, and also resets all other plugins.
    Thanks for testing. I'll fix the packaging mishap for the Start Optimiser (sorry for the inconvenience).
    I have updated the release with new packages.
    Tested and working!
    In Cura 5.0, the Octoprint Connect Plugin seems to interfere with the DuetRRF plugin. When I have both installed (for different printers), for DuetRRF configured printers, I still get the "Print with OctoPrint" button in preview, but the correct DuetRRF menu in the caret menu on the action button. Choosing one of the DuetRRF options from the menu fixes the display, but I was confused for a hot second here.
    I don't know if this is a Cura shortcoming or a shortcoming of either of the plugins.
    @hwa The "Print with OctoPrint" option in the caret menu should only be there if an OctoPrint instance is connected to the printer in Cura. Can you check on the DuetRRF printer in Cura (for which I guess you don't have an OctoPrint instance configured) you don't have a "Print with OctoPrint" option?
    I have two printers: one is an Ultimaker Original+ which I use OctoPrint with. The other is a different machine which runs RepRapFirmware. I would expect the "Print with OctoPrint" only to show up while the Ultimaker Original+ is active.
    I _think_ what happened here was that I switched from the Ultimaker to the other printer and since I hadn't selected a default option for the DuetRRF plugin yet, Cura still showed "Print with OctoPrint" rather than selecting one of the DuetRRF plugin options.
    Now that I did set a specific action for the non-OctoPrint printer, it does not show the "Print with OctoPrint" option anymore, although that is still listed in the caret menu.
    It should not be. I think that is a Cura bug, but I'll have to look in to that.
    Yes that worked, Thank you for that, I now have mesh tools in cura 5 🙂 Its a wonder its not in cura by default the ability to split models into parts which ungroups them for editing ? Perhaps in a future issue it could be in there the ability to ungroup models and the rest of the mesh tools ? Its in there but greyed out ?
    Steve..
    I have added some more prereleases. The last of my official plugins that still needs an update is the Material Settings plugin. I hope I'll have time to work on that tomorrow.
    • Like 3
    Saving the best for last?
    Sing with me. "TOOOOMorow, tomorrow, I love you, tomorrow, you're always a day away"
        This update is for...
        All UltiMaker S series
        New features
