The code looks fine. I think your Z speed or your Z jerk or your Z acceleration is faulty. Or too much friction on the Z. Try moving the Z up and down by 10mm movements to see how it does. You can do this from the menu system.
41 minutes ago, gr5 said:The code looks fine. I think your Z speed or your Z jerk or your Z acceleration is faulty. Or too much friction on the Z. Try moving the Z up and down by 10mm movements to see how it does. You can do this from the menu system.
yes, a sticky/dirty z axis was the problem
1
- gr5 locked this topic
dailyworkshare 0
Always share some amazing and informative information with us, Thank you for sharing the detail.
