Great, thanks a lot!
I added some oil and down-regulated printing speed as you described and it worked now indeed. I cannot say which of the two measures was the main contributor but the result looks just as I hoped it would.
Just out of curiosity: Did you also make it work for even softer materials, or is this as good as it gets? If I see it correctly Ninjaflex and Arnitel have around the same hardness (85 A/34 D).
gr5 1,858
I haven't printed this exact filament but I've printed Ninjaflex which I think is even softer. Try two things:
1) Print at 10mm/sec
2) Add oil
So the oil - people think it's crazy. People think it will affect the material (it doesn't). People think it will create holes in the print (it doesn't). It just works. Try it.
So I put the UM3 on the edge of a table and unspool as much as possible so it hangs down almost to the floor. Add one drop of light oil (sewing machine oil or 3-in-1 oil or any light oil - probably baby oil will work - don't use food oils as they will go rancid - only use petroleum oil). Ad the drop to the filament before you insert so it gets in the bowden. Then add a second drop once the filament is inside the bowden - add the drop just below the feeder. The drop will slide down the filament. Every hour or so (really every meter which is probably every 2 or 3 hours) unspool some more filament until it is almost touching the floor again and add another drop of oil.
gr5 1,858
Note also that you can play with speed and temperature live - while it's printing - from the tune menu. If it's printing well you can try speeding it up by 50% (to 15mm/sec) and watch it for a bit. Or try raising the temp by 5C. Or both.
