Cura 5.0 wont even start. Immediate crash and totally usless. Any fix?
earth_inheritor
Posted · Cura 5.0 wont even start. Immediate crash and totally usless. Any fix?
I was super excited to use Cura 5.0 but clearly it wasn't ready for release. I never could get Beta to work and now the full release has the same, unfixed, bugs.
First time, i tried starting it, splash logo, white screen and immediate crash and total freeze.
Uninstalled every version, wiped out the AppDate Cura folder, all profiles, materials, backups every hint of all versions.
Started perfectly, setup the ocotoprint plugin, did a test print, print finished, immediate freeze.
Rebooted, immediate white screen freeze exactly like before.
Nothing to do with plugins and those didnt exist the first time around.
Log seems to just stop at shaders and gives no error data.
Someone on reddit suggested an Nvidia shader issue but i dont see how thats possible when it started after removing all AppData for Cura and it worked once and never again.
So what the heck do i do now?
