GregValiant 1,490
There it is from two of the guys that really know.
There are two new settings that have an effect on this. They are in the Walls section "Split Middle Line Threshold" and "Add Middle Line Threshold". I have not played with them much, but they tend to limit the extrusion width allowing for a higher counts in narrow places. They are percentages rather than some hard coded absolute.
To paraphrase from the popup help balloon - Increase the number to use fewer and wider lines and decrease to use more and thinner lines. So it would appear that there is some adjustability in the max line width.
Edited by GregValiant
ahoeben 2,047
Quoting @ghostkeeper from this reddit post:
ghostkeeper 105
So then reducing the Minimum Wall Line Width will allow it to print with two walls then, using thinner lines. Does that not solve your problem?
Effectively, you could see the Minimum Wall Line Width simply as the threshold at which it starts using more, thinner lines.
