Dim3nsioneer 556
Is it an UM2 or an UM2+? @CarloKmight certainly know better but if it is a not plus printer (and firmware) could it have something to do with the fixed nozzle of the UM2? Either in the firmware or in Cura.
CarloK 184
Can you open the generated gcode file on your computer?
In the first few lines it should show something like:
Verify this nozzle_diameter value to what you expect. I just checked with Cura 5.0 and this looks ok. I don't have a UM2+ printer here to check what the printer shows.
