GregValiant 1,115
It depends on when someone gets around to looking at the forum.
I didn't have any trouble slicing the model (Ender 3 Pro) but parts of it won't print. The details are too fine OR pieces just aren't attached too other parts and will fail. The front door is a 4 panel but the panels themselves won't connect to the stiles and rails. You can just make out the vertical gap on the right window frame as well. The roof is so thin that it will only print as separate bridges extending the long way across. Those will fail as well.
On the left is the model after repair in MS 3D Builder and on the right is the model as you posted it. You can see that there are a lot of errors in your model.
Scaling the repaired model up to 200% helped with the gaps like in the door. You can't really print a small scale "to scale" architectural model. Certain things (like the front door and windows) need to be designed with the FDM process in mind. That means that a glass window can't have it's thickness to scale but rather at maybe quadruple thickness so it will print. The four panel front door might need to be a caricature of a 4 panel door, not the exact door.
psycloneII 0
Im new to the forum, so could someone please le me know if I've posted my question in the correct forum or sub-forum?
