U2 not starting the print in the center of the buildplate
shikhar.df3d
Posted · U2 not starting the print in the center of the buildplate
I am trying out my first print. The printer is starting in the front left corner and is trying to print where the glass clamp is. I immediately aborted the print in order to prevent any damage to the nozzle.
I checked my files for any stray parts of the model, but the files are alright.
How do I get the U2 to print in the center of the buildplate?
    It's the machine center 0,0 thing. The center of the plate is *not* 0,0 (it's roughly 116,116). So uncheck that. You probably didn't select an ultimaker2 as your machine so you may have other issues also.
