GregValiant 1,330
My disclaimer: I have a "virtual" dual extruder Ender 3 Pro in Cura that I use for troubleshooting. I have no real life experience with them.
When both extruders are enabled and with a model on the build plate you should have the option in the Bed Adhesion section. You can see it in the image below. Next to the Settings Search box is an icon with three lines. Click on it and set the visibility to "All".
One thing I've learned about dual extruders is they each have there own settings. I have to be very careful checking all the settings for both extruders by switching back and forth between extruders. It's fairly easy to make a mess.
1
GregValiant 1,330
That looks a lot like a purge tower. In the Dual Extrusion settings you can turn it off.
If you happen to be using one extruder for the model but the Build Plate Adhesion is set to the other extruder you will get that. I think if you disable an unused extruder (there is a check box) then it will go away as well.
Garywoo 0
Thanks Greg, I clicked on Settings > Extruder 2 > Disable Extruder, and this stopped the circle being generated.
Where do I define which extruder prints the Build Plate Adhesion?
