Here are some pictures of my problem. My Hotend is behind the buildplate, so I can't configure the buildplate
- Solution
Your print head is mounted backwards. Remove it by unclipping the rods that go through the print head from the sliding blocks and rotate the head 180 degrees.
3
1 hour ago, IRobertI said:Your print head is mounted backwards. Remove it by unclipping the rods that go through the print head from the sliding blocks and rotate the head 180 degrees.
Thank you very much. This is a school printer, someone must have messed it up. This will be an easy grade on my exam!
1
GregValiant 1,330
And when you asked the class who did it - did they respond something like this?
2
MariMakes 201
Hey @joostttbosman,
Welcome to the Ultimaker Community 🚀
Do you have some pictures for us so we can help troubleshoot?
I can ask around for some assembly manual, but first we need some more information on what is wrong.
Thank you 🙏
