Yes, we do have a spatula - I was trying to use that and basically was breaking the supports - which obviously wasn't a big deal because they were supports, but it was still super hard to get off. I ended up taking a rubber mallet and whacking at it to dislodge it - which isn't a great option lol.
I'll keep the idea in mind of putting the whole buildplate either in water or the fridge/freezer and see how it goes - thanks.
MariMakes 201
Hey @oakcreeklibrary,
I've had some printjobs being really stuck to buildplates before, there is always a way to get them loose 😉
A spatula is a musthave printer accessory to get printjobs loose from the buildplate. Do you have one?
With PVA it's supposed to be quite easy, you can just remove the whole buildplate from the printer and drop it in a bucket with lukewarm water. Or even have it under a running tap of warm water for a bit.
I've also seen people put their whole buildplate in a fridge or freezer. When your printjob cools it will be easier to remove with the shrinkage and settling of internal stresses.
