Material not compatible with S5 Material Station
flyntm
Posted · Material not compatible with S5 Material Station
I am trying to print with Fiberforce Nylforce Glass Filled material on a S5 Pro.  I installed the material profile from the Ultimaker Marketplace.  When I try to print, I get an ER64 message saying that the material is incompatible with the Material Station.  Much to my dismay, after reviewing the Marketplace Tech sheet for the Nylforce GF is says that it is not compatible with the Material Station.
1) Why would a material be incompatible with the Material Station?
I tried to work around this by finding a GF nylon material from the Marketplace that is compatible with the Material Station.  This works, but at the end of each print, it shows this message: "The material seems to be stuck in print core 1. Start the wizard to safely remove the material and continue print."  The material is easily removed and does not seem to be stuck.  It has done this several times.
2) What's going on?
3) Is there a better work around?
4) With a Material Station, is there a way to use the "on the back spool holder"?  I couldn't seem to find a way in the S5 software to do this.
Thanks for your help
    Flyntm,
    This is an ongoing problem with my Ultimaker. Super frustrating. The only material my machine sees are the originol Ultimaker materials that i purchsed with teh machiner which have now run out. Backspooler doesnt make a difference. I have been looking for answers on this for some time and will now post on the message baord. Good luck!
    Hi
    Yes, unfortunately I know the problem too. I then use generic profiles and get the same result.
    Background could be that the parameters for unloading the materials are only on the printer itself hard deposited.
    Everything that can be unloaded without problems with the existing profiles is compatible, everything else is not.
    Ultimaker likes to point out that these releases for the material station give the manufacturers themselves.
    Practically, however, probably Ultimaker itself stands in the way. For example, by not being willing to make these parameters accessible in the material profiles.
    The material is apparently properly pulled out of the print head but the sensors go on alarm.
    It is obvious that the material sensor gets a bit confused when more material has to be pulled.
    At the end of the material, a thickening tends to form during such actions. This could then not be pulled through the material station in every case.
    Therefore ER64. If you bypass the error and the assistant (e.g. by switching off the printer) you will still not get the material back into the station in some cases.
    If you rebuild on the spool holder, the material remains in the printhead until you manually unload it.
    At least this way you get rid of these considerable maintenance times.
    So was my knowledge stand over a year ago. Perhaps something has changed.
    I also hope that Ultimaker creates a solution for this.
    greetings
    Hi Ulrich,
    Thanks for your reply. Would you mind clarifying your statement, "If you rebuild on the spool holder...".  I'm not clear on what this means?
    Also, do you have a suggestion for a work around to use a material that is not marked as compatible with the Material Station?
    Thanks again!
    Hello
    with the conversion to -spool holder- I mean nothing more than disconnecting the material station.
    Unfortunately, only the material station or the spool holder works. I have always mounted the spool holder to the printer.
    (I think this is a part that usually comes with the S5).
    Sometimes I do the work and remove the material station and put in the spool holder.
    Unfortunately, to do this I also have to remove the material station connector at the back of the printer.
    I often work with generic generic profiles with third party manufacturers.
    Practically, I only need to copy the print temperatures and speeds from the marketplace profiles.
    I don't go to the trouble of creating new profiles. I just create a new printer for this purpose.
    The dimensions of the prints are set with test prints. Unfortunately, the latter never fails to occur with CF materials.
    (Example for colorfabb xt-cf20)
    But I am now a bad example of -how to do it right-.
    For me, it's often about having a plannable amount of time.
    Many greetings
    Thank you,  Now I understand. 🙂
