Posted
(edited)
· Change to print from Nozzle 2 mid print
What we do is separate TWO different stl files and simply put on on top of the other. Then set one stl to use nozzle number 1 then the other to use nozzle 2.
A bit tricky aligning, but as long as you use the co-ordinates within Cura ( x and y the same for each model and z would set above the first layer - "Part Thickness" )
Hope this helps......👍
Edited by Carbon
Carbon 29
Edited by CarbonLink to post
