Problems when printing with PP (Polypropylene)
AnaLara
Posted · Problems when printing with PP (Polypropylene)
I am trying to print a piece with PP (Polypropylene) with my printer Ultimaker S5, but the results are terrible.
The warping is considerable and sometimes the pieces cannot keep sticked to the bed for a long time,
even I am using a special glue for that (Magigoo).
These are the parameters which I am using:
image.thumb.png.5d341faa11b8bc52e9bf631bce996189.pngimage.thumb.png.4b830c8f82355b935cd76834286d950d.pngimage.thumb.png.e24b58e80c21bce0375f41c73f1ea30c.pngimage.thumb.png.e8a05a363dde5c7d8b7f81d2d4251c1b.pngimage.thumb.png.0e3c57d48e5376dcce403a1a98e57d12.png
Could you please tell me if I am doing something wrong? In the data sheet of the material, it appears this:
Thank you!
    • 4 months later...
    bumping this topic. hope you found some answers.
    do you have the airfilter as well?
    having the same problem, same machine.
    did have some good results but from a set of 7, only 1 came out real good. very inconsistent.
    When I was printing with PP, I put packaging tape (PP based) on the entire print surface. The printed object fuse with the tape and give a good bonding.
    When I print with PP, I set Adhesion on (Brim) and use a glue (Magigoo for PP) much. These can give a good bonding.
    Recently I make small size grooves near bottom corners .
    These grooves prevent parts from bending.
