That won't help me now! Was hoping there should be a safety kill switch connected to the digital factory but seemingly not?
The print would have been "Aborted" the head will go to home position and the glass bed will lower. The printer will now stay in that state until the "Confirm Removal" blue button on the printer screen has been pressed.
Wouldn't worry about "head overheating" issue as the heads will not stay heated.
13 hours ago, Carbon said:The print would have been "Aborted" the head will go to home position and the glass bed will lower. The printer will now stay in that state until the "Confirm Removal" blue button on the printer screen has been pressed.
I can 100% confirm that this didn't happen. The head moved to the front left (as you look at it face on) and the build plate remained in the raised position. I repeatedly checked it for over 48hrs and it stayed like this.
I don't have a screen grab sadly as I phoned security of the school and had them pull the plug so the printer is now forced offline.
Dim3nsioneer 557
I use a WiFi switch.
