Luke, What material are you printing? With the S5, you can use PVA or breakaway in the second nozzle and get great results. Did you design the support yourself? or did you let Cura build the support structure? Your photos of the object look really odd to me, are you using the 0.8 nozzle? I don't think we have enought info to really help you. Just guessing here.
GregValiant 980
I'm not very familiar with the UM machines but in general...
In the end though, a good set of "support removal tools" is a must. Being able to work the support out of tight places and leave the cleanest surface possible is a learned skill and requires some practice.
@MariMakes is from UM and is a moderator here. She does a lot of work with smallish models and may have a take on the support issue as well.
