I have removed both cores, and reinserted them to be sure. The nozzle does move up and down by hand. It basically just seems like it doesn't save the calibration. During calibration it works fine, but as soon as I start a print it moved over to flip the switch and misses.
As far as I can see you performed the calibration just fine. The behavior in the second movieclip is normal. At the beginning of the printjob the printer makes no assumptions on the position of the lift switch. The move that you see is to make sure the switch of towards the front of the printhead.
What error do you run into when you leave the printer to finish this printjob?
Edited by tomnagelUpon starting a print once active leveling is complete it gives the Lift Switch Error. I am not even able to start a print.
The first probe is supposed to be done with the right nozzle, and the second probe with the left core.
Then the grid probing should be done with the left nozzle.
I think the best thing you can do is create a support ticket on our website
I would check your Y Limit Switch, its just out of view on both of the videos so I cant tell.
But generally when the lift switch is not being toggled properly its a sigh that your limit switch is damaged.
Y0pher, did you get this fixed? I am having a similar issue and can't fix it... (Email julia @ makergirl . us if you feel inclined to help me!). When I try to manually move the lift switch it doesnt move either so i cant figure out how to fix this. I also have the most updated software!
4 hours ago, MakerGirl said:Y0pher, did you get this fixed? I am having a similar issue and can't fix it... (Email julia @ makergirl . us if you feel inclined to help me!). When I try to manually move the lift switch it doesnt move either so i cant figure out how to fix this. I also have the most updated software!
If you cant manually move the lift switch, that generally means the head was not reassembled properly.
See section "Switch function broken" here: https://support.makerbot.com/s/article/000002889
- Solution
After contacting support we discovered the problem was actually with the axes being unaligned. When looking down on top of the printer the Y axe was slightly at an angle. After adjusting it is now hitting the lift switch as it should. I'll include the link to the instructions they sent me.
https://ultimakernasupport.zendesk.com/hc/en-us/articles/115004168943-Aligning-the-Axes
gr5 edit:
If above link doesn't work try this: https://support.ultimaker.com/s/article/1667412443401
1
- 1 year later...
On 3/8/2023 at 4:40 PM, T0pher said:After contacting support we discovered the problem was actually with the axes being unaligned. When looking down on top of the printer the Y axe was slightly at an angle. After adjusting it is now hitting the lift switch as it should. I'll include the link to the instructions they sent me.
Any chance that you have a copy of this link? That one doesnt seem to be working
Here's the new link. I'll edit that post also.
You don't need to print that tool. Some of my UM printers actually came with the tool. You could instead try a few blocks of wood until you find one of a thickness where the screw faces in a favorable direction.
fbrc8-erin 316
On 7/4/2024 at 10:08 AM, NikoPiros said:Any chance that you have a copy of this link? That one doesnt seem to be working
@NikoPiros I have an updated link: https://support.fbrc8.com/hc/en-us/articles/25226273083675-Aligning-the-Axes
I've also got a quick video I made for the process a while back. I'm planning to get a better video uploaded in a week or so: https://youtu.be/zEI2mLc5iZw
2
Travis7s 28
Is your #2 PrintCore fully inserted correctly? it should be lit up during these tests I think? You should be able to visually confirm the nozzle moving up and down when you toggle the lift switch by hand.
