Instead of using "Change Material" use "move material" (under advanced settings). Wait the hot end to reach the temperature. The jog dial is used to control the extruder motor. Use one hand to pull back the filament while with the dial move the motor in the same direction.
illuminarti 18
Do change material again, and this time pull the filament while it's trying to expel it.
