Thank you very much for the feedbacks, yes this is a new problem, I do have 3 printers and I am having this problem with one of the printer, 99% printing PLA and Breakaway, after reading Dustins feedbacks, I did check the fun and I did start another print with setting the print temp 15 degree more may be this can be a solution.
I will update you soon.
Thank you
Dustin 193
As your issue sounds to be some what random.. It would lead me to believe the issue is related to your UltiMaker Cura profile.
Possibly your printing with the extruder too cold or speed too fast.
Additionally it would be worth checking the front cooling fan to make sure its clean and spinning correctly
