It looks like at the end of the print, the {machine_extruder_end_code} is set to the last tool position in the used extruder stack rather than the last extruder tool that was used.
example; print two items each with different heights, each with different extruders (multi extruder setup) swap the extruder order, its missing the last {extruder_end_gcode} in both cases. If you add the line {machine_extruder_end_code} to the printer_end_gcode box,the output for {extruder_end_gcode} is pointing to the last position in the extruder stack regardless of what tool code was used last.
I think it should include the start and end code for each extruder, and point to the last extruder tool used at the end.
Hope this helps
Gero 54
How about a little download link to the beta so that we can try it out right away? 😉
Edited by GeroLink to post
MariMakes 208
CLICK HERE TO DOWNLOAD THE CURA 5.4 BETA
How about this?
I've also updated the post so it can be found there as well. Thanks for the feedback @Gero 😊
Gero 54
Ah, missed the link and clicked the "react to post" button instead. Gonna try again
